KR632 Motherboard with AMI bios won't handle 120 GB HDD
culpr1t
Trying to install a 112 GB hard drive on an older computer:
120GB: KR632 Motherboard - American Megatrends Bios: 61-1217-001540-00101111-071595-440LX-1440L000-H
The bios id, interestingly enough matches the AMI format, but the 1440L000 doesn't start with AMI so I'm not sure what to do with it.
The hard drive as far as I can tell should have:
(tried to set it up in CMOS settings as User but cylinders field only could handle 5 digits in current bios)
size cylinders heads sect size mb LBA 32bit md BLK md P10 UDMA
123891 232632 16 63 123891 On On ON 4 5
culpr1t :?
That is a GVC/BCM motherboard. Let me see if we can find anything about it anywhere. Normally we can only patch Award bioses for LBA48 code, so this one you'd need to set the drive to 32GB limit and use an OS that knows how to handle the drive directly without the bios interfering (windows XP SP2 and up, recent Linux flavours). There is a very remote chance there's a bios that can handle larger disks, no guarantee on that. I'll have a look in the archives...
culpr1t
Thanks, edwin!!
Currently running Windows XP SP-3 so that's ok... Appreciate your help/research.
Carry-on and we'll see if there's anything useful. :wink:
culprit
BIOS Guru
http://www.bcmcom.com/tech/kr632/KR632.htm
This should be your board and I assume you already have the latest Bios. On Startup there should be a text notice on the screen just below the AMI Logo -does it show A08 or A10 ?
Just as Edwin said, try to jumper your drive to 32GB (usually via a jumper), space above should be accessible within Windows.
Another option you could try :
Enter this HDD specs manually in Bios, use 1024 cylinders, 16 heads, 63 sectors and enable LBA. This was at least a workaround to overcome the 32GB bug on a Pcchips M715 but I don't know if it bypasses the 64GB problem as well.
culpr1t
Denniss - Thanks for the comments, suggestions. I will see what I can find and respond with data soon.
Thanks again!
culpr1t
culpr1t
Dear Denniss,
It shows A10 on boot. When I tried "Enter this HDD specs manually in Bios, use 1024 cylinders, 16 heads, 63 sectors and enable LBA. This was at least a workaround to overcome the 32GB bug on a Pcchips M715 but I don't know if it bypasses the 64GB problem as well.", it did not
work. I still haven't pulled the drive out to see if I can hard strap it for 32Gb, but will later today?
More anon..
culpr1t
yeah, you'll need to strap that one down and remember to set it for single drive use if there's no other device on that IDE cable. See the manual on wdc.com
