Advice/Help Needed!!!
VilleV
Ok! I flashed my bios and all went well (at least I thought so) but there was this message at the end that said "disable usb" or something similar.
After that I booted the computer. Now it doesn't work.
I tried to get my old bios back but couldn't get it to work. I also tried several other versions but they didn't work either.
My computers' floppy-drive reads the disk and after that computer beeps four times, restarts and does the same thing again and again.
I also cleared CMOS --> didn't help.
Here's some info: MB - k7s5a ver. 3.1
bios - amibios
I used amiflash utility ver. 3.35
So I was wondering what should I do next? Could I get it to work by reprogramming the bios chip or should I just give up and get another mb?
BIOS Guru
What's the Bios you used to flash ?
Have you freshly formatted the Floppy before flashing anything ?
Try copies from newest Bios to older ones renamed to AMIBOOT.ROM and save it to a freshly formatted Floppy to try the emergency Flash
Maybe you need the Cheepobios - OC-Version based on ECS 021129
If all this does not work strip your system down - remove all PCI cards except VGA + remove RAM except one and remove IDE cables
