Latitude D510 motherboard dead...
som1dies2nite
When powered with the power brick, the power button just blinks 3 seconds at a time. It will not boot, no fan, no drive and it will no go into BIOS as well. Another weird thing...The charging LED doesnt light up with battery installed.
NickS
BIOS Bodhisattva
Did you flash the BIOS just before this happened? Some laptop BIOSes include a keyboard controller BIOS and the keyboard controller is often also used for power control.
som1dies2nite
No I did not. Is the BIOS chip the same chip as the EEPROM or are they completely separate?
NickS
BIOS Bodhisattva
The EEPROM contains the system BIOS, but if you have (fdor example) a Hitachi H8 as a KBC, that is often reprogrammable with its own firmware too. That firmware may be included in the manufacturer's BIOS flash package. IIRC, you'll also find in the Notebooks section a couple of sticky messages warning about unexpected reasons why flashing may kill a laptop e.g. flashing with both memory slots full.
som1dies2nite
NickS - Are you familar with Dell laptops? Would the security chip that Dell has on laptops the same chip that contain the BIOS? The chip is 24LC04.
NickS
BIOS Bodhisattva
No, the 24LC04 is too small - 4KB.
som1dies2nite
So the 24LC04 is the sercurity chip and saves settings on it. The BIOS chip is a different chip in all?
NickS
BIOS Bodhisattva
som1dies2nite wrote:The BIOS chip is a different chip in all?
Yes. It could be something like 29F010 to 29F040. However, the BIOS may instead be included in something like a Intel i82802 Firmware Hub (FWH) device which provides 4Mbits for firmware.
som1dies2nite
NickS, the security chip in the D510 is 24C04 or something similar starting with 24xxx but havent seen 29F010? What type of chip is that? The inte i82802 chip I believe is not the BIOS chip but a chip that uses the intel drivers for SMBus.
NickS
BIOS Bodhisattva
som1dies2nite wrote:NickS, the security chip in the D510 is 24C04 or something similar starting with 24xxx but havent seen 29F010? What type of chip is that?
Google for 29F010: "29F010 Datasheet - 1 Megabit (128 Kx 8-bit) CMOS 5.0 Volt-only, Uniform Sector Flash Memory"
Google for "Firmware hub": "The Intel® 82802 firmware hub (FWH) discrete component is compatible with several Intel chipset platforms and a variety of applications."
