Onboard Sound Option Not Shown In Bios
JamieTEA
Hello
Sorry I am a newbie here and after searching for hours through previous post and doing multiple searches I cannot find an answer to my question.
I recently reformatted my HD on an EI Systems notebook after a HDD faliure.
Loaded everything again but although I have the correct drivers for the onboard sound Via Technologies AC97 codec combo (WDM) which worked fine before, when I try to install them again the notebook reports 'onboard sound not activated in BIOS' and refuses to load.
I reboot and enter the BIOS screen but there are no settings available to enable or disable the onboard sound.
Could anyone tell me if there is a hidden menu via some shorcut to find these settings.
My BIOS is as follows....
American Megatrends version 1.08
Release date: 10/13/2003
Boot Devices: Floppy, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Capabilities: Flash Bios, Shadow Bios, Selectable Boot, EDD, BBS
Supported Standards: DMI, APM, ACPI, ESCD, Pnp
Expansion Capabilities: ISA, PCI, AGP, USB
I have full system specs if needed as I ran the Everest test program and saved the results.
Any help greatly appreciated, and sorry if this is posted in the wrong section
Jamie
This sounds more like using the wrong drivers or a missing UAA/HDA patch from Microsoft. What is shown in your device manager?
JamieTEA
Hi
Not sure what info you are asking about from the device manager but presumably relating to sound.
Everest reported the following
Audio Controller Type: Intel 82901DB(M) ICH4
Codec Name: Unknown
Codec ID: FFFFFFFFh
If I dont use the audio driver setup package and go directly to audio driver update in device manager I can ınstall the drivers ok but the system reports the device failed to start and has a problem code 10
I know the drivers are correct as they worked fine before the format
Looking on other forums they all point to enabling the onboard sound from the BIOS setup menu however there is no option available in the menu. I have the advanced tab but only the IDE setup, CD-ROM setup and IRQ settings are available. Thats why I asked if there was a hidden menu of some kind for the onboard sound
I wondered if maybe I have a corrupted BIOS and the onboard sound settings are missing?
What model is it exactly?
JamieTEA
It is an EI SYSTEMS notebook made by Dixons and bought from PC World. Their support is not worth writing about. They sell then forget!!!
If this helps this is the everest reports on the system
Manufacturer: DIXONSXP
Product: 755IX
Universal Product ID: 00020003-004005-006007-008009
Motherboard Chipset: Intel Brookdale GI845GEV
Motherboard ID: 63-0100-000001-00101111-101303-i845$1ABHI016
CPU Type: Intel Celeron 2600 Mhz (26x100)
Audio Adapter: Intel 82801DB ICH4-AC97 Audio Controller [B-0]
Hope you can help
JamieTEA
The drivers didnt work same problem code 10. You mentioned a possible missing patch from microsoft. What is this and where can I find it
Jamie
nubi
hello
i read your topic..
this problem same my probelem..did u solve this...i cant find ..code 10 problem ....and no sound seetings in bios....my computer is fujitsu-siemens 7830d ....pls..if u find a solution reply me...
thanks....
http://www.gigabyte.com.tw/Support/Moth ... FileID=836
this handles the KB835221/KB888111 problem.
nubi
thanx for reply edwin..
i installed ...but still no sound(code 10 error)
my comp. config is:
fujitsu siemens notebook amilo d 7830
intel broakdale i845E
ami bios updated 1.08c version
ati mobility rodeon 9000 vga
audio controller: intel 82801 ICH4 -ac 97 audio controller B-0
audio onbord : via VT1612a
DMI Mainbord: uniwill (755IA5)
i try everyting ?
1.foramated xp
2.diffrent drivers
1.xp can fouund new hardware when i deleted driver
2.no sound setting in bios
3.in device manager (no plug and play devices )...serial(serial.sys) shown error.
what can i do...this problem started after format my disc...
thanx
